Difference in engine builders bore stroke combos >
Old 04-03-2020 | 07:45 AM
Default Difference in engine builders bore stroke combos
Whats the advantage or reason engine builders swear by their bore and stroke combos in high performancr big blocks
mercury 1350 run 557c.i
sterling runs 557
cheif runs 572
teague runs 565
some others run 588, 598 etc
whats the differance running blowers in hp range from 1100 to 1500hp bore and stroke engines
Fresh is offline
Old 04-03-2020 | 08:00 AM
Its really all just preference really.
Adding stroke adds torque and pulls the powerband down.
Adding cubic inch can allow you to make more power on pump gas with a blower.
Putting a 4.500" stroke in a STD Deck block is possible but it kills BDC stability and just makes a real pile of **** combination.
Some builders probably prefer to use short strokes and turn 6,200 vs longer strokes turning 5,200.
You can make the power you ask out of a bunch of engine combinations.
c0ncEpT is offline
Old 04-03-2020 | 09:46 AM
sterling runs 557
cheif runs 572
teague runs 565
Well there are 2 common deck heights which is confounding your comparison. 9.8 and 10.2.
Assuming we’re talking about Dart blocks, the general consensus is you shouldn’t run the 4.6” bore size popular with NA apps. So you’re talking 4.47-4.56ish.
For strokes, in a 9.8” deck block, everyone is fine with 4.25” stroke. Some debate whether 4.375” significantly reduces bore life. So in a 9.8 block, 4.5x4.25 gives you 540, 4.57x4.25 gets you 557.
In 10.2” deck height block you could go up to 4.5” stroke. 4.5x4.5=572. 4.56x4.5=588
More aggressive stroke in a 10.2 is a 4.75”
hogie roll is offline
Old 04-03-2020 | 10:21 AM
Default Dart block
Yes would be a dart block. Since i will be running a hoodscoop probably should go with a tall deck 10.2 . Also a 1471 roots blower. Boat would be used for poker runs and occasional trips to sand bar. What you thinking?
Fresh is offline
Old 04-03-2020 | 01:58 PM
I would build either a 589 or 572
4.560" Bore x 4.500" Stroke - 589ci
10.200 Deck
6.660 rod
.100 in the hole
8:1 CR
4.560" Bore x 4.375" Stroke - 572ci
10.200 Deck
6.700 rod
.100 in the hole
8:1 CR
c0ncEpT is offline
Old 04-03-2020 | 03:01 PM
Default Whats your reasoning
Have shiroff racing shooting me ther numbers 36k for a 588 with 1471 1050hp on pump gas
Hp numbers seem low for that combo what you think. Why would you go with 572 589?
Fresh is offline
Old 04-03-2020 | 03:17 PM
The 565s always seem to make good hp and have a decent life span.
underpsi68 is offline
Old 04-03-2020 | 04:10 PM
Roots just aren’t great on pump piss, too much heat.
If it were me, I’d do a 10.2 588 around 7.5 to 1 with a non intercooled whipple 510 and a mild cam with around .600 or less lift.
I think that would get you to 1200 around 8 psi. Should be relatively reliable and low maintenance.
Old 04-03-2020 | 04:15 PM
Try Eddie young, Teague, Sterling or BUP on here. Eddie does 1100hp fuel injected whipple 598s.
Old 04-03-2020 | 06:15 PM
Ok i will just but i dont want fuel inj. Just carbs
Fresh is offline
