496 mag ho exhaust
496 mag ho exhaust
Hi. Heard that a 496 mag ho needs open exhaust or silent choice due to the high power or you can burn your valves and the engine can run hot.
is this true?
i got a 496 mag ho in our cruiser and thought about remove the silent system.
is this true?
Mercury says to never run your silent choice, closed, over 2600 rpm.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
[email protected]
302-521-0123
cruiser boats route exhaust different ways and so forth but It sounds like you have a bravo 3 ?? twin engine boat ? if so then you will have the standard Y pipe and then thru the transom and out the open end sleeve ? Anyways put some pics up if needed or explain exactly what you have for exhaust and the set up / routing
its a single engine boat with a bravo 3.
for now i have a silentchoice from mercury
and a standard y pipe through the transom and to the open sleeve.
And i want to remove the silentsystem and replace it with 4" "elbows" down to the y pipe.
And just wondered if this may couse trouble due to high resistance to the exhaustflow
couse i heard that the ho models need open exhaust at higher rpms
