Where to get 4" exhaust hose? >
Old 04-11-2020 | 04:54 PM
Default Where to get 4" exhaust hose?
I'm swapping my 260 carb for a 350 mag mpi the exhaust is bumping up to 4" where's the best place to buy this stuff without paying $10.00/mm?
Not sure how much I exactly need but I'm guessing 5' total for both sides.
on a side note. Could I run 4” stainless tubing with the rubber on each end?
Alwhite00 is offline
Old 04-11-2020 | 08:11 PM
Rookie's Avatar
Where in Michigan are you? I bought some at my marina and it really isn't cheap anywhere you get it. I might have a couple feet laying around my pole barn in Muskegon.
Ebay has it for $18/ft
Rookie is offline
Old 04-11-2020 | 08:34 PM
Would it be ok to run SS tube with the rubbers on the ends?
I may take you up on that 2’.
I’m in the thumb.
Old 04-11-2020 | 09:10 PM
Rookie's Avatar
I've run 4" stainless inside the 4" ID high temp silicone hose for years. You just can't use hose that is non-supported/rigid hose, because the hose collapses and opens when under power. It's a pretty neat phenomenon.
If it's water cooled I don't see an issue.
Rookie is offline
Old 04-12-2020 | 08:21 AM
yes, it’s wet exhaust. I’m picturing 4” SS tube with a 6” piece of the reinforced rubber on each end. Not exactly following what the high temp silicone hose you are mentioning. Is it like the cold side turbo stuff or am I way off?
Old 04-12-2020 | 08:28 AM
I've ran this setup.for a few years with no problems. HPS couplers and Ebay pipe.
https://www.ebay.com/itm/4-x-4-OD-DI...2-3bb9e1663467
Ryan00TJ is offline
Old 04-12-2020 | 08:32 AM
https://hpsperformanceproducts.com
Believe I used 4 1/8" size so 4" pipe easier to push in.
Ryan00TJ is offline
