Holley HP EFI conversion >
Old 12-14-2020 | 10:42 AM
  #101
articfriends's Avatar
Originally Posted by Rookie
I have the sensors and will have it hooked up on the dyno. Like others have stated it is all engine specific. Hopefully I can data log during the dyno and then just set to known good and look for anomalies.
I recently bought a twin channel plex knock sensor system too for my dyno but havent tried it out yet
articfriends is offline
Old 12-14-2020 | 10:59 AM
  #102
I would like to se the results from these. My past experiences have me jaded towards them not being reliable enough to save a piston/pistons if timing, fuel pressure go astray.
abones is offline
Old 12-14-2020 | 11:12 AM
  #103
Thumbs up
Aboners, that came out really nice!
ICDEDPPL is offline
Old 12-14-2020 | 11:31 AM
  #104
Thanks Dan
abones is offline
Old 12-14-2020 | 12:55 PM
  #105
Rookie's Avatar
Smitty, Here is the link to the male end of the TPS sensor harness. This is what I used to connect my Ford TPS to the Holley harness. This also is for the pressure senors.
https://www.ebay.com/itm/Namz-Delphi...cAAOSw6DBfuULi
Rookie is offline
Old 12-14-2020 | 01:14 PM
  #106
Originally Posted by abones
Thanks Dan
is it attached to the intercooler ?
Edit: your intake seems tall...
ICDEDPPL is offline
Old 12-14-2020 | 01:48 PM
  #107
mounted to the blower boss, square stock one side cut on an angle, flat stock mounted to it for the coils to mount directly to the flat stock
If you expand this photo it should show the mount
abones is offline
Old 12-15-2020 | 07:36 AM
  #108
Funny story about Knock sensor and mefi. Before I had my own dyno and started tuning mefi, a friend of Mine, lets just call him "TYLER" tuned one of my blower motors on his dyno and then on the water. I think we had some mechanical knock or something on dyno so knock sensor got turned off temporarily. So fast forward, when I bought mefi burn and learned how to use it, I find the ONLY safety that Mefi really has , the knock sensor, has been turned off since motor has been in boat (like two years). I think of the times I held it at 6300 at 13/14 psi for 10 minutes a few times and Im just like OOPS! no ashtrays though, luckily!
Old 12-15-2020 | 07:38 AM
  #109
Old 12-15-2020 | 07:55 AM
  #110
Rookie's Avatar
You only running 6 cylinders to make it fair? lol
Only the 4/7 swap no 2/3?
Mine are 2/3 and 4/7.
Rookie is offline
