Holley HP EFI conversion >
Old 01-06-2021 | 08:36 AM
  #171
Rookie's Avatar
Originally Posted by Panther
If I'm looking at this right, you should be able to use this module, a dual sync and only one IGN1A inductive smart coil?? (Holley Coil)
https://forums.holley.com/showthread...ition-Problems
Rookie is offline
Old 01-06-2021 | 09:22 AM
  #172
i would use a larger coil designed for distributer ign vs the ign1a which is designed for cnp
b18cls1 is offline
Old 01-06-2021 | 09:40 AM
  #173
Rookie's Avatar
I understand that. I was just looking at the advantages of using an inductive coil over a capacitive coil. Unless the larger coil is inductive. During my research others talk about the benefits of the longer spark duration of an inductive coil vs the quick hitting of a capacitive coil. I may be off base because my needs will never exceed what I have. lol
Rookie is offline
Old 01-06-2021 | 03:08 PM
  #174
Panther's Avatar
Frank's Marine Service
Not sure Rookie. Haven't done that yet.
I can tell you that I was able to run the setup I posted with both a canister coil and a GM two plug coil. Was told the GM two plug wouldn't work and it worked.... lol I decided to use a canister at the end of the day.
Panther is offline
Old 01-07-2021 | 11:59 AM
  #175
Rookie's Avatar
Found it. I keep learning more everyday.
Rookie is offline
Old 01-08-2021 | 07:46 AM
  #176
Panther's Avatar
Dyno'd the 454 yesterday with the Holley HP conversion. Long block is stock 454MPI Mag. It made pretty much what I expected out of the setup. For the majority of the tuning I was able to use the self-learn feature and saved a ton of time. Once done I set the learn parameters to 5% and I'll do the final tune in the boat and then turn self-learn off.
Panther is offline
Old 01-08-2021 | 07:56 AM
  #177
Rookie's Avatar
Nice! What is that combination? That appears to be the same #'s I'm looking for out of my engines. I have never dyno'd my combination, but assumed 560HP/580TQ on my builds. Soon to find out though.
Thanks!
Rookie is offline
Old 01-08-2021 | 06:23 PM
  #178
articfriends's Avatar
Thanks!
Think it was one of those weird holley blower kits that bolted on top of a MPI lower manifold on a mpi engine, if Im thinking of same motor me and frank talked about
articfriends is offline
Old 01-08-2021 | 08:40 PM
  #179
Rookie's Avatar
Thus the 600+ lb-ft of torque and 560HP. I was thinking that was a lot of power for a 454 at 5000RPM and below. I was planning 5800. lol
Rookie is offline
Old 01-09-2021 | 08:59 AM
  #180
what cam are you gonna run or thinking about running.to get a 454 to make 560hp gonna need a cam in the 240,248 range w/ lift to match heads
sutphen 30 is offline
