Holley HP EFI conversion >
Old 12-05-2020 | 10:23 PM
  #71
Smart man :-)
These are the ones I run .
https://www.holley.com/products/igni.../parts/556-112
ICDEDPPL is offline
Old 12-05-2020 | 11:14 PM
  #72
can't go wrong w/ these coils,,they pack a punch and don't require more than 4.5msec of dwell.
Amazon Amazon
sutphen 30 is offline
Old 12-06-2020 | 08:08 AM
  #73
https://www.amazon.com/ACDelco-Ignit.../dp/B00KCWUQ00
I agree with Sutpen 30, these are the coils I use with my MEFI 4B and they do pack a punch!
abones is offline
Old 12-06-2020 | 09:24 AM
  #74
Rookie's Avatar
Originally Posted by ICDEDPPL
Smart man :-)
Dan, do I need any other harnesses besides the 558-312? https://www.holley.com/products/igni.../parts/558-312
They mention 558-307.
Also, I commented on your post in the "Classic Offshore" section "Post Your Oldschool Ride". I had no clue... You man, are a miracle worker.
Those are the coils I have in my cart now. I was going to post them in the morning. I guess you guys beat me to it.
Rookie is offline
Old 12-06-2020 | 12:34 PM
  #75
That`s my wiring parts list, you`ll need the 307, it plugs into the 312 ( I`m pretty sure I remember that right) There will be some changes to that harness, mostly you`ll be cutting out the 18 gauge wire and going with something in the 10 gauge. Then you`ll be tying some wires together and running one single ground to the head and another ground to the battery . (pins C and D) take care to look that over well... I remember the directions and colors were confusing .
ICDEDPPL is offline
Old 12-06-2020 | 12:38 PM
  #76
307 harness
PIN C:
All the reds and browns go together to a single source :
I think this was the Pin B ground:
ICDEDPPL is offline
Old 12-06-2020 | 12:44 PM
  #77
You`ll also need a coil relay.
I fused it using this one :
I needed a few more spots for grounds and power this came in handy :
ICDEDPPL is offline
Old 12-06-2020 | 12:53 PM
  #78
One more bit of advice is go to your print shop and have them blow up the instructions. Hang em somewhere.
You can thank me later after you see how tiny the included instructions are .
ICDEDPPL is offline
Old 12-06-2020 | 01:13 PM
  #79
Amazon Amazon
Used those to prevent any interference , lots of electrical stuff in close proximity back of the engine.
ICDEDPPL is offline
Old 12-06-2020 | 02:36 PM
  #80
Rookie's Avatar
Thanks for all of that information!
I see a lot of guys on YouTube with instructions blown up. I believe that is there first thing they tell you to do.
Rookie is offline
