Holley HP EFI conversion >
Old 04-17-2020 | 06:28 AM
Originally Posted by Rookie
(Smitty, can this regulator be used as 1 IN, 1 OUT and 1 Return OUT???) It would make a lot easier to mount the regulator next to the pump and filter.
https://www.racetronix.biz/product.asp?ic=reg-fi886bs
yes,you put an o-ringed cap in the unused inlet.
sutphen 30 is offline
Old 04-17-2020 | 07:49 AM
Rookie's Avatar
Originally Posted by rv
Take a look at an old Cutler system. It will show you an option to solve your problem.
Thanks, I have old cutler systems. They were hard plumbed similar to what I am doing. I'm using larger fuel rails -8 vs -6, larger regulator and my fittings are just really large to fit in the same footprint using the same fuel schematic.
Rookie is offline
Old 04-17-2020 | 08:04 AM
Rookie's Avatar
? I was thinking like this. In theory it should be no different than what I was trying to accomplish. Also the route that I have in the above pics will work, it just looks a little sloppy.
Rookie is offline
Old 04-17-2020 | 08:08 AM
F-2 Speedy's Avatar
You cant put a spacer on the boss where the rail mounts instead of using an L bracket ? or do the holes not line up
F-2 Speedy is offline
Old 04-17-2020 | 08:28 AM
Rookie's Avatar
They are on my printer now and should be complete by the time I get out of the shower.
Also, no additional holes have been drilled yet.
Rookie is offline
Old 04-17-2020 | 08:49 AM
F-2 Speedy's Avatar
printing spacers, gotta luv it....
Old 04-17-2020 | 08:54 AM
To reduce chance of vapor lock
AllDodge is offline
Old 04-17-2020 | 09:47 AM
Rookie's Avatar
Actually added 10° bend and 1mm thickness overall.
Rookie is offline
Old 04-17-2020 | 10:09 AM
regulate at the end as AllDodge suggests.
kvogt is offline
Old 04-17-2020 | 10:40 AM
For what it's worth, this is how I plumbed my EFI. Had similar situation to you getting around the distributor. Also, I ended up putting the regulator directly on the even side fuel rail (easy plumbing the return line) and then I just plumbed the odd side fuel rail with line coming off the pump & filter.
rvander68 is offline
