New guy with 383 and cam questions >
Old 06-24-2020 | 05:55 PM
  #31
GPM
Originally Posted by SB
Maybe this will help the OP.
How fast did it go this way ?
Never clocked it, it was a turd across the board
GPM is offline
Old 06-24-2020 | 08:02 PM
  #32
GPM
[QUOTE=traviar;4745111]▲▲▲▲▲▲▲▲▲▲ Yeah how fast did that go? I'm not trying to push my family boat to 80MPH. haha
You won't
GPM is offline
Old 06-25-2020 | 08:32 PM
  #33
I "borrowed" SB's cam from his 350 for my 9.8:1 partially forged 383.
It's
Comp Cams OE roller style CS 268XFI HR13 Cam
Valve Lift .570” Intake .565” Exhaust
Duration at .050 lift, 218 Intake 224 Exhaust
Advertised duration intake 268, exhaust 276
113 Degree Lobe Separation Angle
Intake Centerline 109 Degrees, intake close 63 degrees after bottom dead center
I got 5300 RPM last September at 65 degrees temperature with half a tank of fuel. If I had kept on it and really trimmed it out there might have been more rpm, but not much.
That was running a 21" Mirage plus through a 1.50 ratio Alpha gen 2 with Amsoil Severe Gear in it and a drive shower.
I have ported iron Dart Iron Eagles, a fresh Davis Unified Ignition, Comp Beehive springs and Comp short travel lifters. My boat is a big fatty compared to OPs.
I always had trouble with higher rpms til last year when i opened up the runners. You gotta breathe to use all the capabilities of the engine.
NHGuy is offline
Old 06-29-2020 | 01:49 PM
  #34
Realized I lied. I had the 19 pitch on that day.
NHGuy is offline
