Big block vs small block
Originally posted by Scarab P-29
Patriot I can forsee a lot of hidden costs like exaust holes.
I just want to get over the 75 mph mark, when you do that you are usually faster that most. I would like to take it for one last ride with the big blocks. That is after I have the props refinished. I know they weren't to bad but knicks are knicks and every little bit helps. Unfortunatly if rerun keeps growing at his rate the the small blocks won't even make a difference.
Originally posted by paradigm shift
...383 and 400 small blocks can have pretty good torgue #'s but I don't think they can match a big block...
It idles nice, and has been turn-key everytime. I went with aluminum heads, intake, and exhaust manifolds (EMI) which probably knocked off a couple hundred pounds...
