Backfire thru carb problem on starbord engine------HELP >
Old 05-22-2020 | 12:56 PM
0F124358
Backfire through carb above 1200 rpm
454 MAG. BRAVO (GEN. V) GM 454 V-8 1992-1994 - 0D805069 THRU 0F304999
The serial number range can be either TB4 or TB5. In another thread OP said there is only 4 wires coming from the ICM which makes it a TB4
Timing should be 8* BTDC
Compression 130 to 145 psi
Swap carbs with no change
Edit: no knock sensor or module
AllDodge is offline
Old 05-22-2020 | 01:05 PM
I'm thinking Dist module 87-892150Q02
Even more so if the module is the old 2 wire style
AllDodge is offline
Old 05-22-2020 | 06:53 PM
phughes69's Avatar
any ticking sound at idle, collapsed lifter, intake valve way out of adjustment, time to pull a valve cover
No ticking at all. engine stars great and idles smooth. Engine is completely stock and has 450 hours on it.
phughes69 is offline
Old 05-22-2020 | 08:45 PM
Valve train or hung valve, doesn’t take much. Pop the valve covers.
spark has to be super screwed up to act that bad without load
sailtexas186548 is offline
Old 05-22-2020 | 10:14 PM
TomZ's Avatar
I’m still banking on the TB-V f’ing up but only because I’ve had similar happen. Hoping it’s not mechanical.
TomZ is offline
Old 05-22-2020 | 10:44 PM
phughes69's Avatar
Was it your module or the pickup in the distributor?
Old 05-22-2020 | 11:35 PM
TomZ's Avatar
Friend’s boat... He was told the module was bad and unobtainable.
I ordered a Voyager conversion for it and ran the hell out of it.
TomZ is offline
Old 05-23-2020 | 06:07 AM
I guess its time to switch distr. and module and see if its not a mechanical problem.
sutphen 30 is offline
Old 05-25-2020 | 05:12 PM
phughes69's Avatar
NEWEST UPDATE---- 5/25/20. swapped over a known good coil, still backfiring. Tried retarding the timing to 0 deg BTDC and even ATDC and still backfiring.
timed engine to 0 deg BTDC, marked the alignment of the #1 tower with the coil tower, spun engine over to 0 deg BTDC on the balancer, pulled the cap off and noticed that the rotor was not pointing towards the #1 tower but was actually about 20 degrees BTDC on #1. Swapped distributors and the engine ran fine and no backfiring. So now 1 of three possible solutions. A bad module, a bad pickup coil, or the rotor was not phased correctly. The module for this distributor is $400 and is obsolete and the pickup coil is another $50. At this point, I dont have ready access to the boat. and have told the guy that we can upgrade both distributors for a little more than the cost of replacing parts on just one distributor. I'm looking either at the DUI distributors (HEI) type distributor or the A-Team Performance (marine HEI ) distributor. I want to replace the whole distributor. Does anyone have personal preference of these two brands or another brand/system that is better?
Old 05-25-2020 | 05:51 PM
SB
The A-Team is complete low cost Chyna right ? Compared to medium cost questionable Chy-na things.
SB is offline
