Backfire thru carb problem on starbord engine------HELP >
Old 05-25-2020 | 06:18 PM
  #31
TomZ's Avatar
GM Delco Voyager EST kit for the win. It’ll come with the coil and wiring as well as spark plug wires for about $450 per side.
TomZ is online now
Old 05-25-2020 | 06:19 PM
  #32
TomZ's Avatar
I think ebasicpower.com has them for $430.
TomZ is online now
Old 05-25-2020 | 06:33 PM
  #33
Agree Delco EST
AllDodge is offline
Old 05-25-2020 | 09:04 PM
  #34
i would check the fuel system from the carb back to the tank,it is easier for the fuel pump to suck air than fuel.through the years i have seen loose fittings on both sides of the screw on fuel filter,cracked fuel hoses,cracked fittings at the tank&fuel selector valves.to me it sounds like a lean condition backfire.add in,i just worked on a 39 sea ray that had your same problem,the seal in the fuel selector valve dried up and allowed air to be sucked past it but it never dripped a drop of fuel.
mike tkach is offline
Old 05-26-2020 | 06:27 AM
  #35
Valve sticking or rocker arm loose? Pop the valve covers?
Nothing personel 353 is offline
Old 05-26-2020 | 06:57 AM
  #36
phughes69's Avatar
only 1 tank that both motors draw off. the port runs fine. Swapped carbs and still have the problem. Swapped distributors and the problem follows the distributor
phughes69 is offline
Old 05-27-2020 | 09:02 PM
  #37
looks like you found the problem.
Old 05-28-2020 | 11:49 AM
  #38
Probably timing sensor if a thunderbolt ignition
Topshelf38 is offline
