454 timing help
Hello, I'm about to adjust the timing on a 1988 merc. 454 330hp. Got the light, marked the TDC line on the balancer and the engine says 8° BTDC . No problem except, the mercruiser manual says its important to jump the purple / white wire to ground coming either from my distributor or the control module attached the the exhaust manifold ( old manual, it's not clear which) . I cant find a purple and white wire . There are only 2 wires attached to the distributor wht/red and wht/green there is no vacuum advance . If you know which wire I need to ground, I'd appreciate it. Thanks
