Fuel pump (suction) >
Fuel pump (suction)
Fuel pump (suction)
Old 06-21-2020 | 10:19 PM
Originally Posted by Rookie
What Mallory pump are you running? I run Mallory 140's. I just went and looked at my Scarab and the pumps are mounted even with the top of the fuel tank. My loop does go down to about halfway down the tank.
140 bottom of unit which is where the pump is right about level with half tank
riverrunner242 is offline
Old 06-22-2020 | 06:13 PM
Here is what I am planning to avoid a suction problem from the high pressure pump.
IHTFP is offline
Old 06-22-2020 | 07:35 PM
yeah I'm just running a carb so I dont have a high pressure pump and I dont have a mech pump provision on my block. Hopefully I need a high pressure pump on my new boat👍
Old 06-24-2020 | 04:17 PM
You could use a water pump mounted fuel pump. That is what I am doing.
IHTFP is offline
Old 06-24-2020 | 04:26 PM
SB
You should start a new thread on that. I see some things that should be changed up.
SB is offline
Old 06-24-2020 | 08:20 PM
‘I’m listening, what do you see wrong with this?
IHTFP is offline
