540 BBC-what spark plugs >
Old 07-21-2020 | 01:35 PM
Default 540 BBC-what spark plugs
Just finished my 540 build, Dart block, Canfield aluminum heads with 9.5:1 compression. Stock heat range plug be fine or should I go a step colder?
I believe I have BPR6ES’s in there now which I believe is stock heat range for 502.
H8TOLUZ is offline
Old 07-21-2020 | 02:13 PM
F-2 Speedy's Avatar
do those heads use a crush washer ?
F-2 Speedy is offline
Old 07-21-2020 | 02:32 PM
If your going to stick with ngk I’d step down to 7’s and keep an eye on your ground straps. I never had much luck with ngk’s except in 2 strokes.
getrdunn is offline
Old 07-21-2020 | 02:34 PM
yes, crush washer style
H8TOLUZ is offline
what is it that makes them unlucky with you?
H8TOLUZ is offline
Old 07-21-2020 | 02:51 PM
Fouling and would rarely pick cylinders back up. I’ve always had good luck with ac delco and autolite. But what ever brand you prefer and have had good luck with. Heat range as you mentioned most important.
getrdunn is offline
GPM
What does Canfield suggest
GPM is offline
Old 07-21-2020 | 03:03 PM
Dint hold me to it but I believe 3924 autolite
getrdunn is offline
Old 07-21-2020 | 03:19 PM
GPM
If so that would be a good place to start
GPM is offline
F-2 Speedy's Avatar
what will this cross over to
NGK R5671A7 4091
