Motors
Old 08-03-2020 | 02:35 PM
Dandridge
BOSS342 is offline
Old 08-03-2020 | 05:00 PM
Internal flappers may be burnt out. Use a flashlight and look into pipes.
PA.WOODCHUCK is offline
Old 08-03-2020 | 11:42 PM
Originally Posted by BOSS342
So I pulled the spark plugs. Put oil in the cylinder turned motor over and had a lot water in one of the cylinders. Got water out, changed spark plugs fires up motor and it runs. A lot of “steam” coming from exhaust. While there is none coming from the motor that had no issue. I turned motor off and then restarted and it starts fine. Checked the oil and it seems to now have a bit of water in it. Will an oil change solve the problem? I had a machanic tell me to just run it and let the water evaporate out because it does not seem to be much at all due to the dipstick showing full but not over full. Any thoughts?
DO NOT LISTEN TO THAT MECHANIC!!!!!!!
You probably have a bad exhaust manifold or exhaust riser leaking water into the engine or if lucky just a bad gasket between them.
It will destroy the engine if you don't get it fixed
Griff is offline
Old 08-04-2020 | 05:52 AM
You need to stop right now and find out where that water came from. Dont run the engine again until you find the problem, period. Every time you try to start it with water in a cylinder you are taking a big chance of bending a connecting rod.
You should probably start by pulling the exhaust manifolds and having them checked.
BillK is offline
Old 08-04-2020 | 07:35 AM
Will do!!
BOSS342 is offline
Old 08-07-2020 | 06:08 AM
Also you say you started the engine and it ran...did you run it on the hose? If not, you probably burned up the water pump impeller. Anytime you run a boat on land, you have to run water through the sea pump or it will burn up.
kreed is offline
Old 08-07-2020 | 07:45 AM
I had the hose and muffs on it
BOSS342 is offline
Old 08-07-2020 | 10:07 AM
resurrected's Avatar
How much water was in the pan? Water if not mixed with the oil (whitish) will be a puddle in the sump and will be first to be pumped through the engine.
resurrected is offline
Old 08-15-2020 | 12:33 AM
Dandridge
I'm in Lafollette. About an hour and a half drive. If you need a hand let me know.
Smitty275 is offline
