Had a Rocker Fail >
Had a Rocker Fail
Had a Rocker Fail
Old 08-09-2020 | 08:48 PM
Great point/question.
If a/that valve stuck....., cam lobe still rotates, raises push rod (is it still straight?) and weak link expires.
Originally Posted by OldSchool
Wouldn't that have happened sooner than 25 hours? Those Jesel rockers just suck. I've had a bunch of them break on a previous boat... with hydraulic lifters. The other engine in the boat (new build) had the same cams and lifters and Crane Golds. No issues...
Twin O/B Sonic is offline
Old 08-09-2020 | 08:51 PM
seafordguy's Avatar
Ugh. I don't like hearing that. Was that on your tiger with the big motors in it?
seafordguy is offline
Old 08-09-2020 | 09:33 PM
my thought was they are all on the edge and this spring is shimmed a little more or has a little shallower seat, causing this to fail first with more on the way. Engine guy building one after the next takes a shortcut and doesn’t check every single spring... Unlikely but an easy check
On another note, I am a steel rocker guy, aluminum is just not right for rockers IMO
sailtexas186548 is offline
Old 08-09-2020 | 10:46 PM
it was a top gun. My buddy got a good deal on it because it had a broken rocker
Unlimited jd is offline
Old 08-10-2020 | 05:35 AM
OldSchool's Avatar
LOL...broken rocker on a tired engine. I think both people involved in that transaction walked away happy. That's all that matters!
OldSchool is offline
Old 08-10-2020 | 07:15 AM
he did get the rest of the season out of that motor so he was thrilled! Lol hope your doing well in retirement land.
Old 08-10-2020 | 08:37 AM
At least it was a clean break right on the end. When they break and send needle bearings into the motor that can cause damage quickly.
apex svt is offline
Old 08-10-2020 | 08:44 AM
I would look at all the geometry and pushrods. Lots of natural deflection in a big block. A new rocker shouldn’t fail that fast. Likely an underlying issue in the valve train
Crude Intentions is offline
Old 08-10-2020 | 08:54 AM
vintage chromoly's Avatar
I called Jesel about the known and common failures on these arms prior to using them.
the engineer told me that they break at the adjuster when guys over tighten the adjuster locknut.
i believe the spec is 22 ft.lbs.
he was adamant that this was really important to avoid cracking them at the adjuster.
vintage chromoly is offline
Old 08-10-2020 | 09:00 AM
What's your valve stem to guide clearance? Most heads come delivered set up for the street, you need a bit more for hard marine use.
ThisIsLivin is offline
