Starter Issues >
Starter Issues
Starter Issues
Old 09-02-2020 | 09:23 AM
I would check the rotor phasing in the dist. the start retard might be causing a problem.
fbc25el is offline
Old 09-02-2020 | 10:05 AM
Are they MSD ?
They are Daytona Boxes and distributors. It is also Carburated I had not mentioned that prior.
RBeyer is offline
Old 09-02-2020 | 10:06 AM
Worth checking
RBeyer is offline
Old 09-02-2020 | 10:09 AM
Originally Posted by RBeyer
It was not shimmed prior to the freshening of the engines and we rebuilt the same starter. We are going to check that this time for sure. It does not have the noise that usually accompanies a shimming issue,
You rebuilt the starter that failed? I had one years and years ago that I had my starter rebuilt and it cracked the nose housing and left me stranded on a late October day. I ended up buying a new starter and never had the problem again. Being locked in at 32 degrees with a hi torque starter should not be a problem. And I have never heard of shimming one, just saying.
1BIGJIM is offline
Old 09-02-2020 | 10:31 AM
F-2 Speedy's Avatar
I meant the starters....
F-2 Speedy is offline
Old 09-02-2020 | 11:25 AM
Because of that we are doing a new starter this time. We obviously will check all else again. Hopefully we will have the same luck you did.
RBeyer is offline
Old 09-02-2020 | 09:02 PM
SABER28's Avatar
were they piece of **** MSD starters like these sold by a lying scumbag company?
SABER28 is offline
Old 09-02-2020 | 10:06 PM
Nope the GM factory high torque
RBeyer is offline
Old 09-02-2020 | 10:09 PM
This one literally busted the nose off the aluminum housing, slightly bent both mounting bolts and took out the bendix. Still no obvious signs of a problem, plugs look great, no water, etc. Lost!
RBeyer is offline
Old 09-03-2020 | 06:37 AM
Rookie's Avatar
I think you might have a timing issue, loose wire, ground, tach or something. I had the same problem on my truck. Broke starter, cracked the side of the block where the starter bolt goes in. It appears that my crank sensor went out during the time I was cranking the engine over. Timing went funky and blew s#it up! lol.
Rookie is offline
