Originally Posted by ecuchips
(Post 4854620)
I made a heat exchanger from DD15 Detroit EGR cooler. It works very well. Easily cools 1200hp. I have added fittings to dump excess water pressure and water pressure gauge. All pretty simple, Just had it cleaned, Pressure tested and then got busy for a few hours with the tig. Easy as...
I've seen prices for used DD15 ERG COOLERS for $600, but don't know what condition.........I get the principles behind their use just would like to know substituting ERG Coolers for the typical closed cooling Shell & Tube heat exchangers are a way around the big cost?.......because ERG coolers go through tremendous heat exposure using a used one would be as gamble, but isn't everything when considered. |
I used a second hand one. The environment is way easier than the environment on the DD15. They have 40 psi at 600 degreed going through them. The cooling is easily enough for a blown hand built 540 running 8psi. The build quality is way superior than a normal marine cooler. Easy to weld fittings on with a tig...Just get one chemically cleaned and pressure tested, and its ready to go...Jas
(Post 4854674)
I have twin 572 BBC's ....but before I jump in need to know how involved & labor intensive to build a system ....give me some confidence Jas! |
Fwiw… I’m using factory Merc 454/502 coolers on my 600+ 509’s. My temps run right around 170-175 cruise and actually drops into the 160s when running harder. water temps upper 70’s to low 80’s.
https://cimg5.ibsrv.net/gimg/www.off...3a418af92.jpeg There was a post from way way back where member VinnyP modified his 575 sci to use a factory heat exchanger. His 575 had been breathed on so I figured would work on mine. So far so good. This is a half system (exhaust is still raw water). Curious about the EGR cooler. |
Originally Posted by TomZ
(Post 4854732)
https://cimg5.ibsrv.net/gimg/www.off...3a418af92.jpeg There was a post from way way back where member VinnyP modified his 575 sci to use a factory heat exchanger. His 575 had been breathed on so I figured would work on mine. So far so good. This is a half system (exhaust is still raw water). Curious about the EGR cooler. maybe I'm watching Bad Chad too much, but if a cooler a 1/4 of the price can do the same job (2 posts back Jas says, detroit dd15 coolers can handle 600* at a much high pressure) easily I'm looking into it. it. |
Originally Posted by scippy
(Post 4854675)
Hey Jas....I've seen one on ebay for $360 used & pressure checked ok...Boy, If I could convert these to my intention for closed cooling that would be great!.....We know how much the PPT & Monitor closed cooling kits cost...backordered & not available till spring.
I have twin 572 BBC's ....but before I jump in need to know how involved & labor intensive to build a system ....give me some confidence Jas! https://cimg9.ibsrv.net/gimg/www.off...80c0a4dea5.jpg Here it is with the ends ready to be welded on https://cimg2.ibsrv.net/gimg/www.off...d82eb9d4d2.jpg |
Picture is worth a 1000 W's ~ Jas, that is so cool!! ...A few questions, how did you disassemble the ends aren't they welded closed? .....and after cleaned tig welded close?
I'm sure there's a lot more involved, but let me keep asking, .The dd15 erg cooler pictured do you happen to know the model #?? ...I came across a Detroit diesel DD15 ERG p/n A4731400175 - And another one p/n A4731400575......They look like yours, but don't know .....I give you the measurements in a couple if you don't mind.....thnx, Scippy |
The dd15 erg cooler I'm looking at is ..32" long & 5"x 5" seems kinda large!
Serious question… If you’re welding up the ends, how do you take it apart to clean? Boiling and calling it good?
(Post 4854758)
| All times are GMT -5. The time now is 02:46 PM. |
