Gimbal pins
Old 10-06-2020 | 08:45 AM
Default Gimbal pins
The lower pin on the gimbal ring that the trim rams attached too has slight play ,any fix for that besides replacing the Gimbal rings? The play again it’s very minimal
i’ve seen that on a lot of gimbal rings so it’s not uncommon I was just wondering
thanks
boatnt is offline
Old 10-06-2020 | 09:10 AM
I don’t think it’s a big job to just replace the lower pin. The gimbal and the bellhousing shouldn’t need to come off, but I think the driveshaft bellow and Outdrive will need to be removed. If I remember right, there’s a bushing that’s the pin rides on, that is glued in place in the gimbal housing.
Old Gringo is offline
Old 10-06-2020 | 09:39 AM
No it does not have a bushing it rides right in the aluminum ears of the gimbal ring, it’s the stainless pin that the trim cylinders attached too
boatnt is offline
Old 10-06-2020 | 09:51 AM
Which way does the play allow it to move?
tmmii is offline
Old 10-06-2020 | 11:01 AM
Just spoke with Ron at jrmarine,normal as they all develop some slight play After some use.
boatnt is offline
