Inlet air temps on a turbo engine vs a blower engine >
Old 10-22-2020 | 02:25 PM
Default Inlet air temps on a turbo engine vs a blower engine
Was wondering which has the coolest air temps.
say at 5lbs of boost in a
1) twin turbo set up
2) roots blower set up
3) Whipple screw blower set up
does cooler or hotter air entering the motor increase or decrease the chance for detonation?
i realize that the cooler the air, the denser the air, the more hp you will make. Just not sure if it has an effect on detonation and combustion temperature.
thanks in advance for any info, RM
iliveonanisland is offline
Old 10-22-2020 | 07:03 PM
The hotter the air, the more chance for detonation.
underpsi68 is offline
Old 10-22-2020 | 09:15 PM
Which of the three power adders listed heat up air the most/least thanks
Old 10-22-2020 | 10:50 PM
Assuming you aren't using an intercooler, if you are than the heat increase between different systems would be negligible at 5 psi of boost. The turbo setup should have slightly lower air temps than the Whipple (screw) style blower but both will be a fair bit less than a stanrd roots style blower. At a low level of boost 5 psi you will not see a huge difference in temp between any of them but the roots will still be hotter. With all that being said if your goal is to run 5 psi any method of adding power should be fine as there is not excessive heat created at low levels of boost. Anything from 8 psi and below should be fine, assuming you can get good gas on the water.
Andrew56 is offline
Old 10-23-2020 | 07:11 AM
Gale banks gives all the temps, output efficiency curves for Whipple vs. 10-71
speicher lane is offline
Old 10-23-2020 | 08:56 AM
If I had to guess, the Whipple would be cooler than the roots. Turbo- it depends. There are a lot of variables to say without comparing specific wheels and housings.
Old 10-23-2020 | 01:33 PM
im just trying to figure out which turbo manufacturer has water jacketed turbos and I will talk to them and have them help me decide which turbo intercooler etc to use in my set up. Basically let them engineer it and I fabricate it and install it
Old 10-23-2020 | 01:44 PM
You`re in Columbia with no parts or support and you`re going to try to build a turbo motor ? Why not just go the easy way throw on whipple or roots and call it a day ?
ICDEDPPL is offline
Old 10-23-2020 | 02:17 PM
I will build it at my buddy’s shop in pa. And rig the boat there and get it all sorted out before I ship it down. Amazon delivers here and I can get stuff shipped for a buck a lb. I’m sure I can find 5.3 motors at the boneyard here if needed in the future.
I have all my tools here and mig and tig welders For building my cars and 4x4s.
my buddy has some cool autoMagic welders for welding tubing etc. I’d like to sell the complete turbo kits if it performs well. He currently sells all kind of crazy frames and parts to make drag bikeS that run on 30 hp Honda equipment engines that started life at 6.5hp lol.
all we have to fabricate is the turbo mount that bolts to someone else’s LS marine exhaust manifold and fabricate the tubing for the turbo plumbing and make the tails so it will fit in a side by side application and feverything else I can buy.
I remember the Renault 1.5L 4 cyl turbo engines from the 80s in F1. They made 1247 hp for qualifying and 900+ in race trim I’m only looking for just over 2hp per ci.
Old 10-23-2020 | 03:47 PM
IMO it won't be as easy as you think finding a water cooled turbo to bolt on to your application, I could be wrong. There might be some trial and error. If it was me, I would put the biggest intercooler you can reasonably fit.
If I'm not mistaken,there is a member on this site with a turboed ls. I think he has it in a platoon boat. Try doing a search.
