-   -   BBC 427 roller cam (https://www.offshoreonly.com/forums/general-q/369729-bbc-427-roller-cam.html)
GPM 12-17-2020 02:03 PM
I would think that RPM range is probably in a longer stroke 454, also an 8 degree split may be better.
GPM 12-17-2020 02:13 PM
Just a thought, Lunati Retro-Fit Hydraulic Roller Cam. High performance street cam. Likes upgraded intake, carb and exhaust. Needs 2800 RPM stall converter in most cases. Requires 9.5:1 compression for maximum performance.; Advertised Duration (Int/Exh): 282/290; Duration @ .050 (Int/Exh): 231/239; Gross Valve Lift (Int/Exh): .600/.600; LSA/ICL: 110/106; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 2200-5800; Includes: Cam Only
F-2 Speedy 12-17-2020 02:39 PM
Is there a part # for this cam 20110712 ?
GPM 12-17-2020 02:50 PM
Lunati, SKU
20010712
F-2 Speedy 12-17-2020 02:59 PM
show it for a GEN 6
GPM 12-17-2020 03:01 PM
I ran the hydraulic flat tappet version of the 231/239 110 lsa in a mild 454, nice idle, pulled right to 5400, shorter stroke 427 should go to 5800 easy.
GPM 12-17-2020 03:03 PM
Originally Posted by F-2 Speedy (Post 4769523)
show it for a GEN 6
Sorry, SKU
20110712
Voodoo Retro-Fit Hydraulic Roller Cam - Chevrolet Big Block 282/290 (lunatipower.com)
mike tkach 12-17-2020 05:30 PM
Originally Posted by F-2 Speedy (Post 4769458)
Ive not built one of these in years, can the step nose cam fit ? I see in the front of the block that it looks like its machined for the retainer ring but not sure
yes, i put gen 6 step nose cams in mark 4 blocks all the time.you use a gen 6 timing chain&gears and a gm cam retaining plate.i have the gm part number for the plate&bolts in the shop and can list them tomorrow.
F-2 Speedy 12-17-2020 05:49 PM
Thanks Mike
