BBC 427 roller cam
#32
Just a thought, Lunati Retro-Fit Hydraulic Roller Cam. High performance street cam. Likes upgraded intake, carb and exhaust. Needs 2800 RPM stall converter in most cases. Requires 9.5:1 compression for maximum performance.; Advertised Duration (Int/Exh): 282/290; Duration @ .050 (Int/Exh): 231/239; Gross Valve Lift (Int/Exh): .600/.600; LSA/ICL: 110/106; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 2200-5800; Includes: Cam Only
#33
#38
#39
yes, i put gen 6 step nose cams in mark 4 blocks all the time.you use a gen 6 timing chain&gears and a gm cam retaining plate.i have the gm part number for the plate&bolts in the shop and can list them tomorrow.
#40
