Mercruiser 496 proplem >
Old 02-26-2021 | 07:41 AM
  #81
SB
GM 12558693 are also AC Delco D581
SB is online now
Old 02-26-2021 | 08:11 AM
  #82
Originally Posted by JohanSweden
When I measure between all of the coils I get these numbers on all of them.
Between +12v and ground = 29-31 Kohm
Between +12v and sparkplug output = 10-11 Mohm
Above I measured after this scheme, and got those numbers.
JohanSweden is offline
Old 03-31-2021 | 03:35 AM
  #83
The engine heads have been overhauled.
Time to start up the engine again and hope it will run fine this time.
When I turn the key on, a relay is clicking constantly. The relay on top of the engine at the ECU. This one:
Why is it clicking?
It happened after this:
I tried to start it up for a first try before the relay startet to click. The engine turned over a couple of times letting fuel pump forward in the system.
Stoped the engine, and cranked it again, this time it only cranked maybe half a turn and I heard a electrical spark or something and the engine stoped cranking.. it smelled electrical smoke so I turned all safety switches off and took of the cables from the battery.
Went all over the electrical system and found two nuts where loose to the slave relay to the starter, strange because I havent touched them. (Yellow cable with red stripe, and red cable with blue/or purple stripe).
Tightened it up and after this the relay is clicking.. have something happened to the relay or maybe something else?
12+ v on starter key and on the main fuse on the engine (the red push button). The engine fuel pump is starting when I turn the key on But it is this relay clicking sound. Dont want to try to start the engine before I have answears what it can be/or what happened.
Old 03-31-2021 | 09:10 AM
  #84
Do you think you blew that fuse link on by the starter? You could test it for continuity.
87MirageIntruder is offline
Old 03-31-2021 | 09:33 AM
  #85
Wich fuse link do you mean?
It says that the relay is ”throttle shiftcable relay”, I dont have the throttle linkage on the throttle body.. can it cause this clicking to happen?
Old 03-31-2021 | 09:48 AM
  #86
I really don't know but I'd have everything hooked up and adjusted like it should be to eliminate any possibilities. You smelled something burn so hopefully you can find it. I've found where the burning happened in the past by sniffing around, usually the smell stays right on the part that smoked.
Here is the fuse I was talking about. Your engine won't crank when this is blown.
Old 03-31-2021 | 10:09 AM
  #87
hmmm I dont have that fuse on my starter....
Old 03-31-2021 | 10:25 AM
  #88
Switched the relay from the other beside this one (it is the same), to see if it was the relay that was bad. But it clicking anyway.
Put the throttle linkage back on the throttle body also, nothing happened. The relay still clicking
Old 03-31-2021 | 11:15 AM
  #89
Make sure your battery and grd connection is tight. A loose ground terminal to starter could give you a burning smell.
underpsi68 is offline
Old 03-31-2021 | 11:46 AM
  #90
No loose cables anywhere where I can find..
I tried to crank her up. It did fire up.. But on the Smartcraft display it says ”warning” and it still clicking. Didnt hear if it clicked when the engine was turned on.
Dont know the fault code yet.
Gonna try to see if I can find it in the VesselView app.
