Ideal method of engine cooling for most consistent temps >
Old 12-29-2020 | 07:22 AM
I couldn’t tell by pics but did you reduce the number of holes with the new 120 stats or you going to wait and see how they react. Tks for the info.
getrdunn is offline
Old 12-29-2020 | 07:30 AM
Originally Posted by SB
Getrdun - if you use tstats you’ll have to get tstat spacer with that intake or mill the divider i guess
That’s a good point. How many times I’ve looked at that intake and saw the divider however never gave it a thought. They went to Jim’s to raise the floors and some porting. I’ll mention to him to remove.
Whats the purpose?
getrdunn is offline
Old 12-29-2020 | 07:52 AM
Originally Posted by getrdunn
Thanks and yes I’m finally on the way to getting in the water. Long project. Business put most on hold. I have dry Stellings to the tip so I’ll have to check that out but certain I will have options. Btw I still need to get john sr on your boat. He’s 80 now even though one would never know it however I wanna get him on the water over 100 mph. 😎
I'm planning on putting the boat up for sale when we return from Arizona for Desert Storm, that's at the end of April, so we need to do it early in the season! or it may not sell at all then we have all summer. Hard to sell a 38FT cat with a full cabin that runs 120 MPH!
abones is offline
Old 12-29-2020 | 09:08 AM
Originally Posted by ICDEDPPL
I have 2 -6AN lines coming off my intake.
Thats how it`s always been .
I grab water temp back there too.
I don`t know what it helps or doesn`t lol
It’s always nice to see the pride you take in your work 👍👍👍. Also Tks for the post. I couldn’t tell by pics however from what I could see looks like you dumping individually as well?
getrdunn is offline
Old 12-29-2020 | 04:21 PM
Thank you .
Dumping them individually above the drives , yes.. I thought about using them to cool the drives but they never really get hot.
For a bravo it might be cool idea
ICDEDPPL is offline
Old 12-29-2020 | 04:37 PM
Rookie's Avatar
I did not put any holes in them. They come with 1 hole in them for air pockets. I will probably not drill any holes in them right away. I'll see where my pressure is an go from there. I also just put those in my Merc 420's w/ 500 EFI cam builds. Those engines ran hotter water and oil than I like with 420 stock hardware. Nothing like spending $160 on thermostats. Why do I do this again... lol
Rookie is offline
Old 12-29-2020 | 05:44 PM
SB
Whats the purpose?
Gives it Direction.
Forces water up there vs the two columns of water crashing into each other, then going up. Water flows similarly to air, but with a little mire weight.
SB is offline
Old 12-29-2020 | 06:16 PM
Rookie's Avatar
Whats the purpose?
I'll cut them out tomorrow while I'm at the shop. lol
Can you quantify mire for me? I must have missed that unit in my engineering classes...
Rookie is offline
Old 01-04-2021 | 02:47 PM
I run in water temps that range from 34 to 76 degrees. I have a 524CI BBC that's a GM Mark IV block with AFR heads and a Brodix HV2000 intake, and Lightning headers. I am running the Hardin stainless pump that I have ported for better flow with a crossover and racing 160 thermostat. It came with 3 3/16" holes and I still have the divider under the thermostat. I added a -10 line from back to front to even out the cooling. According to my lab grade IR temp gun the front and rear of my cylinder heads are with 2 degrees of each other. I have slightly modified the headers to allow for more flow as well. When running wide open across the lake I run about 165 on the gauge. idling for any length and I'm 140-150 if the water is warm. When Lake Huron is cold, I'm lucky to hit 130 pushing it. My oil cooler is a bit too small, but with Amsoil as long as I'm under 300 degrees I'm fine. I couldn't ask for a more consistent and even cooling system.
ThisIsLivin is offline
Old 01-04-2021 | 05:10 PM
SB
Yes. My finger pads are worn slanted. I pressed ‘o’ on my phone keypad but got ‘i’. So, tried to type ‘more.’
lol
SB is offline
