29’ fountain width question
Is the 29’ fountain twin engine actually the same size as the 29’ single engine? As far as width, and weight? Other than the weight of the engines of course. Thanks guys for any info given in advance.
Google 29 Fountain specs.
https://www.topspeed.com/boats/fount...r-ar34300.html |
Okay thanks!!
Converting twin engine to single engine on a 93 29’ fountain
The reason I’m asking is I’m converting a 1993 29’ twin engine to a single engine and wondering has anyone done this?
Bulk head, stringers, and transom already had been redone. But would like to know if this is being done by other people. It’s a 1993 model 29’ fountain. Also opinions on hp to put in it to run decent. If this has already been discussed or there’s a thread here please lead me to it. I’ve been trying to search older forums on it. Thank you again guys.
Originally Posted by swan2
(Post 4772764)
i have a buddy here that took a twin and turned it into a single, but he did massive changes, cut down, made it a sit down, put a windshield on it like a PR. |
(Post 4772769)
The stepped boat had different size steps but you don’t have to worry about that.
i have a buddy here that took a twin and turned it into a single, but he did massive changes, cut down, made it a sit down, put a windshield on it like a PR. should weigh the same with no engines?! I’m not even sure if they made a single engine 29’ fountain in 1993. |
The hull is the same. The stringers are just set up differently.
Originally Posted by Griff
(Post 4772806)
Ok so how much horse power am I going to need to push this boat into the mid 70’s? It’s a 1993 29’ fountain non step bottom. And I’m converting it to single engine. I’m about ready for power now. 🙂
| All times are GMT -5. The time now is 12:42 PM. |
