ratio?
Old 11-15-2002 | 08:54 PM
Default ratio?
With a Bravo 1, which ratio is better? 1.5 or 1.36? Thanks, 88
88 MACH 1 is offline
Old 11-15-2002 | 09:50 PM
Vinny P's Avatar
I hate the winter!!
It is not a matter of which one is better, it is which one is right for your combination. Most of us use the 1.50 ratio. The 1.36 ratio is for guys who are running big enough power to be able to turn a prop with that low a ratio. The lower ratio will cut down engine r.p.m. , but you need to have enough power to do that. It can be best equated to driving around your car in 4th gear rather than shifting up through the gears.
Vinny P is offline
Old 11-15-2002 | 10:04 PM
I'm running a 454 with 500 hp. Sounds like I need the 1.5. Thanks, 88
Old 11-16-2002 | 02:07 AM
merlin540
1.50 that will work the best for you
Old 11-16-2002 | 07:53 PM
Thanks Merlin540
PROMAN
Drives and Lower Units
3
10-15-2007 04:23 AM
saulesses
Prop Talk
1
06-13-2007 09:12 PM
saulesses
Prop Talk
0
06-11-2007 11:01 PM
Chief Apache
Apache
8
04-30-2004 04:40 PM
Garry
10
01-27-2002 10:35 AM
