Need a set of 502 heads >
Old 03-25-2021 | 01:44 PM
Default Need a set of 502 heads
Hey guys, doing a rebuild of my gen 5 502 .060 over looking to make 500 hp w/ maybe a hp 500 cam. My builder said my 3 yer old EQ heads need work and were not worth doing and I should buy new heads. Any suggestions would be appreciated. Are aluminum heads out of the question, I run salt water occasionally but always flush, boat does not sit in salt overnight.
niteridder64 is offline
Old 05-05-2021 | 02:32 AM
Still looking for a set of heads for my build, 509 long rod gen 5. Also looking for a cam and springs to go with it. Any recommendations or sales would be appreciated
Old 05-05-2021 | 07:31 AM
I have NEW Merlin heads 500.00 each.
269 0val
320 Rectangular
345 Rectangular
Sporl Performance is offline
Old 05-05-2021 | 11:43 AM
How can your 3 year old EQ's be that bad?? Even new heads need to be gone through to check tolerances.
Griff is offline
Old 05-11-2021 | 07:40 PM
Default eq heads
I do not know but I saw them and the seats where shot and valves slopping around in the guides. I thought the castings where still good but the shop said the material was too thin to cut in new seats and would not recommend using them. I am relying on his word. but I would not let him keep them for sure.
Old 05-11-2021 | 07:44 PM
I found a good deal on new inconel ex valves. My question is what is the diff between the stock length and stems that are .100 longer. My build is a 509 long rodroller cam w/ about 600/620 lift, 1.7 rockers, which do I need? Also will stock gen 5 pushrods handle that lift w/ 140 seat pressure.
