Merc 575 540ci questions >
Old 12-30-2003 | 10:16 AM
Firewalker
Default Merc 575 540ci questions
I am looking at a merc 575 540 ci motor, I am not sure of the year, but assume 80's.
I am looking for the specs on this motor and any pictures and information possible.
Like reliability and real hp.
Thanks for any help
Old 12-30-2003 | 12:38 PM
jrz
This might work better if you give me an old style fax number, I will try to attach a file to this post.
jrz is offline
Old 12-30-2003 | 12:39 PM
jrz
Did not work.
jrz is offline
Old 12-30-2003 | 12:50 PM
Biggus's Avatar
Here are some specs for the 1988 Mercruiser 575
HP 575@5000
540 CI
Bore 4.440
Stroke 4.375
compression ratio 8.75:1
Fuel 88 octane
Crank, L.A. Enterprises
Block, Iron, Siameses bores
Rods, Carillo
Pistons, Forged
Heads, GM iron rectangle port
Valves, intake Stainless steel
Exhaust, Inconel
Cam, Crane solid lifter flat tappet
Rocker arms, Crane rollers
Intake, Weiand single plane
Carb, Holley 1050 Dominator
Exhaust, Stelling tubular stainless headers
Fuel pump, Carter Hi Performance
Oil pump GM Hi Perf.
Ignition Mercruiser Thunderbolt IV
Sterndive options were Speedmaster III or IV
Biggus is offline
Old 12-30-2003 | 01:02 PM
Biggus's Avatar
Here a pic
Biggus is offline
Old 12-30-2003 | 01:08 PM
Firewalker
Damn you guys rock.
Thanks for the rapid response.
Any idea, on the life span?
Thanks again.
RT
Old 12-30-2003 | 01:17 PM
rmbuilder's Avatar
MarineKinetics
Biggus,
The Merc part # for that cam is 12475. Do you have the Crane #?
Thanks,
Bob
rmbuilder is offline
Old 12-30-2003 | 01:22 PM
Biggus's Avatar
Sorry RM, I do not .
Biggus is offline
Old 12-30-2003 | 01:33 PM
jrz
Lifespan=Short
jrz is offline
Old 12-30-2003 | 01:34 PM
Firewalker
I am assuming cam?
