502 mpi swapped to 600hp carb
Hey guys I bought a 2001 32 fever with 502 mpi motors in it. Was water in the oil ( havnt investigate yet ) but had the opportunity to purchase fresh 600 hp 515. Looking for input on fuel delivery and ignition as I’m sure my factory stuff isn’t sufficient or not applicable for the new motors
distributor and coil from mpi can be used on new motor and your new motor I take it has no meh. fuel pump.so either get a low pressure electric carb pump or use a regulator w/ a high pressure igh volume pump.return fuel back to the tank.
30 hp just in increased displacement. $425 difference in turning the old crank or a new stroker crank . New rods are about the same as rebuilt ones with new bolts. Pistons are a wash . And a 502 crank has some value, say $100? So the way I looked at it was for $325 additional I get 30 hp that doesn't require anything additional, no better fuel, no additional rpm . I felt it was a deal, curious how they did the math
