The Woooples are alive!
Nice idle in neutral in your video roughly 800rpm....great for maneuvering/shifting when you need it and good manners around the docks----also those Whipples look great, and looks like a nice install job too.
Sounds good ! Did you use the learn function on the Holley or do the tuning manually ?
I found learn was all over the place , as far as work ing the table down .
Are you useing the large table 31X31 Tables or 16x16 ?
Had a guy that tunes at ton of everything , tell me that a boat would run better with small tables,
because the ecm didnt have to interpolate as much .
The learn function does screw things up at idle.. I do like to use it to fine tune the tune but after 2000rpm.
Using smaller tables .
Haven`t had a chance to put it in the water yet for tuning.
MR MIKE I ZOOM machined some new longer bigger tabs for me and they are getting a cerakote clear coat next week.
