Fuel Pump
Old 05-04-2021 | 08:44 PM
Originally Posted by Rookie
Pretty sure I ordered the same bracket. Did not get the one for the filter, I can add it later. Also ordered the same coupler. Did this before I saw your picture. Looks like you decided not to use the output fitting that came with the pump.
jeffswav is offline
Old 05-04-2021 | 09:31 PM
Rookie's Avatar
No, it's a check valve. I just used an -6ORB to -8AN fitting. If I need the check valve I can install at a later date.
Rookie is offline
Old 08-26-2021 | 11:37 AM
Just to give a update. I used the AEM fuel pump with recommended AEM regulator and it is working fine. No more lean conditions.
jeffswav is offline
Old 08-26-2021 | 05:14 PM
Rookie's Avatar
Good to hear. My friend has been running ~700HP from his 540's all summer with those pumps. They have been running better this summer than they ever have.
Rookie is offline
Old 08-26-2021 | 09:04 PM
Ton
Glad you found something that works well...I run Weldon 1100-A and it also works perfectly.
Ton is offline
