Bravo-merc 525 water pressure issue >
Old 05-17-2021 | 12:35 PM
F-2 Speedy's Avatar
Originally Posted by Rheeder218
the water pressure has been like this since day one of owning the boat (5years). I back flushed every cooler and hose and tightened all hose clamps. With the inlet hose off the water pump. (Hose from transom assm to water pump). The one side is less water flow in with boat just sitting in the water. At cruise that engine is 3-4 psi less. At full throttle I have 47psi on the port and 29psi on the starboard. The starboard one is the one I’m having an issue with.
thats crazy high........even the 29 seems high to me
F-2 Speedy is offline
Old 05-17-2021 | 12:38 PM
I get 3-4 psi at idle on my 525. Service manual says max pressure at speed is 43 but I regularly see higher than that and so do many others so 47 is fine. The 29 psi I'd be concerned about, as you are!
Edit: F-2 Speedy, I respect your knowledge but lots of us run that high of pressure on a 525.
thirdchildhood is offline
Old 05-17-2021 | 01:13 PM
madbouyz's Avatar
Bravoitis on the stbd side ?
madbouyz is offline
Old 05-17-2021 | 01:24 PM
Can’t get videos to upload to show the difference of water flow from inlet hose off transom assm
To post a video, you have to upload it to youtube and post the link.
My vote is you have a partial obstruction somewhere.
With closed cooling like the 525EFI, I think 40psi at WOT is fairly normal.
Griff is offline
Old 05-17-2021 | 02:24 PM
F-2 Speedy's Avatar
Well I stand corrected, cuz I don't run antifreeze motor's......
Old 05-17-2021 | 02:30 PM
F-2 Speedy's Avatar
Originally Posted by Griff
10-11psi of water pressure at idle is a ton. Mine at idle is about 2 psi. More important is what is the water psi while running?
Ya, this still baffles me, how a single bravo pump can move that much water at idle, I guess drill 8 holes in the other lower and call it a day............
Old 05-18-2021 | 01:50 PM
4 year old fresh water transom assm
Rheeder218 is offline
Old 05-18-2021 | 01:56 PM
SB
1st thing always is to put something thru each water opening in the oil cooler.....as previously told. Doesn’t take much for a few or. 10 or 20 tubes to get something in them.
Many times back-flushing does squat.
Soeaking of which always amazes me how many big chunks of impeller I find in entrance of oil cooler in a boat with an impeller that’s in good shape. Person changing the blown apart impeller dumb or lazy or couldn’t give **** ? Doesn't’ wonder ‘Hey, wonder where the pieces went ?’
SB is offline
Old 05-20-2021 | 09:04 AM
I guess I’ll go through all coolers again. But this all started as soon as I put the boat back in the water this year. Only thing that has changed is I had the drive gone through. The motors keep same temp at 150. Only difference I can physically tell is the top of the header collector gets warm and other stays ice cold. I tried loading videos to you tube to post but it’s not working if someone could help that would maybe help Thanks
Old 05-20-2021 | 09:43 AM
SB
Okay, well...,
Maybe recheck the drive to transom water transfer oring and if okay check lower drive to upper water transfer oring. Maybe f’d up or ??? during service/installation.
SB is offline
