Trim Indicator Issue >
Old 05-24-2021 | 10:48 AM
Default Trim Indicator Issue
Put brand new trim indicator in Apache when redid and one side shows way down from other but boat runs flat and tabs look same on hoist. Can these be adjusted to equal out indicator.
tks
Bad to the bone is offline
Old 05-24-2021 | 12:36 PM
tks
Got pics? I had to replace all of my cables for the trim and the tab indicators. The trim had to be adjusted since they were spring loaded. Basically, I put the motors all the way out, connected the indicator line, and then it was showing correct on the dash when I put the engines all the way in or out.
Barnacle Bill is offline
Old 05-24-2021 | 12:48 PM
Default Apache
geez hope not but way off now thanks for input will get pics next weekend
Old 05-24-2021 | 12:51 PM
For me to adjust mine, it was basically loosening two hose clamp type devices and tightening when they were set correctly on the out drives.
Old 05-24-2021 | 12:57 PM
hope mine the same probably not knowing my luck
Old 05-24-2021 | 01:02 PM
Is the indicator for the drives or tabs? I am a little confused. Both are adjustable, but the procedure is different for both.
snapmorgan is offline
Old 05-24-2021 | 01:04 PM
its the tabs drives work great
Old 05-24-2021 | 01:06 PM
Tabs are different, but a bit easier in most cases.
Old 05-24-2021 | 01:12 PM
F-2 Speedy's Avatar
If I recall this is a #6 boat, if so there are no external rams to adjust like a bravo
F-2 Speedy is offline
Old 05-24-2021 | 01:18 PM
Default Apache
that it is
