block paint
Old 06-08-2021 | 05:23 PM
Default block paint
what paint are you guys using to paint the blocks and heads? I just replaced my SBC block out of my donzi and the heads where cleaned. I see they have a couple different paints like the mercusier phantom black and the 3 step paint as well. Which one of these are you guys using? Thanks in advance. Hoping to get the boat in the water before july 4th weekend!
hypforlife32 is offline
Old 06-08-2021 | 05:57 PM
any high temp enamel would be fine…
1MOSES1 is offline
Old 06-08-2021 | 06:05 PM
If black, just any good enamel. For colors, I use a hardened automotive acrylic enamel.
CDShack is offline
Old 06-08-2021 | 11:37 PM
okay thanks. That should work. Just wanted to make sure it matched the other motor the best I could.
Old 06-08-2021 | 11:38 PM
yes. It’s the factory black I was going after
Old 06-09-2021 | 08:46 AM
I just painted mine with Acrylic Urethane with hardner added
253 is offline
Old 06-10-2021 | 11:49 AM
I like the high temp ceramic paints. They tend to last longer.
Barnacle Bill is offline
Old 06-10-2021 | 01:42 PM
TomZ's Avatar
I used black high-heat gloss engine paint (rattle can) on the block and a high-heat rubberized coating over paint on my oil pans to repel water and prevent rust. I also do brush-on touch-ups before dropping in (something always gets scratched).
TomZ is offline
Old 06-11-2021 | 08:08 AM
The most important thing is prep. I clean the block and use a pain prep solvent before I prime it. I used etching primer and Phantom Black this time. I got it fairly cheap... We'll see how it holds up.
HawkX66 is offline
Old 06-11-2021 | 10:54 AM
This sounds like the best approach i think. These engines dont seem to run too hot. I ordered the OEM 3 stage primer, paint and clear that they use. Ill upload some pics when i get it done over the next week
