Lost rpm
Old 06-15-2021 | 09:10 AM
resurrected's Avatar
Can a drive tighten up without scattering?
resurrected is offline
Old 06-15-2021 | 09:12 AM
I would also check the fuel tank vent hose for a kink or blockage.
fbc25el is offline
Old 06-15-2021 | 09:19 AM
F-2 Speedy's Avatar
What EFI is it ? if its TB have you swapped them ?
F-2 Speedy is offline
Old 06-15-2021 | 09:31 AM
splashandburn's Avatar
Originally Posted by SB
valet mode.
Well, things like fuel tank , gas in it, and supply line and fittings wheren't at dyno.
a cracked spark plug or two from engine installation not uncommon
ive eliminated that by running off an external 5 gallon tank with the exact same results A cracked plug is possible but not likely That motor went back in first and there's plenty of room.
splashandburn is offline
Old 06-15-2021 | 09:33 AM
I thought about that but I think with the HP I'm pushing it would have exploded by now
Old 06-15-2021 | 09:36 AM
They're 500 efi's that were punched out to 540's. I have not tried swapping TB's yet . . .
Old 06-15-2021 | 09:37 AM
Old 06-15-2021 | 09:40 AM
F-2 Speedy's Avatar
I was thinking they were carb style efi, MEFI 3 , 4 ? who tuned it ?
Old 06-15-2021 | 09:52 AM
I believe they're MEFI 3. Tuned by the builder. We used the exact same program that was used before the top ends were done. Tuning was originally done on the dyno and then fine tuned in the boat using welded bungs in the headers.
Old 06-15-2021 | 10:09 AM
what are you running on inlet side of prochargers, ive seen them suck filters partially closed and create a big restriction. happened to a friends 35 cig, wouldn't do it on dyno, but did it in boat
J. Hordubay is offline
