Lost rpm
Old 06-15-2021 | 10:15 AM
splashandburn's Avatar
Originally Posted by J. Hordubay
what are you running on inlet side of prochargers, ive seen them suck filters partially closed and create a big restriction. happened to a friends 35 cig, wouldn't do it on dyno, but did it in boat
The inlet sides are open - no filters other than a thin mesh
splashandburn is offline
Old 06-15-2021 | 07:33 PM
are the intercoolers clean,spider webs,,mouse nest,.......
I'd put a scanner on it and see if your tripping the knock sensors.
sutphen 30 is offline
Old 06-15-2021 | 10:53 PM
Originally Posted by resurrected
Can a drive tighten up without scattering?
No
Griff is offline
Old 06-16-2021 | 12:00 AM
Internal exhaust flapper stuck partially closed somehow??
Not really familiar with prochargers. Is it normal for them to not make any boost until 4500 RPM??
zz28zz is offline
Old 06-16-2021 | 06:34 AM
I did check the intercoolers and they are clear of any instructions. Knock sensors is something I need to check
Old 06-16-2021 | 06:40 AM
There are flappers in the tailpipes but they're just the rubber ones from CP Performance - I don't know how they could not be forced open. Something to look at though.
It is normal to start seeing boost around 4200 - I'm seeing around 2 psi on the other motor @ 4500. The Prochargers are based on rpm.
Old 06-21-2021 | 09:30 AM
So over the weekend I swapped blowers and intercoolers and the problem has not changed. I put a smaller prop on the side that I'm having an issue with and was able to run the rpm up to 4800 but again saw no boost. At that rpm I should be seeing close to 5 psi and running that smaller prop with ANY boost I'd have hit the rev limiter easily. I think I've ruled out pretty much everything. I'm leaning towards an intake leak but how would that go bad from the dyno to install?
Old 06-22-2021 | 04:23 PM
There’s no way that the tensioner is acting goofy and the belt is slipping is there? When I had m3SC’s in my BT I had to tighten the port blower belt to what seemed like overkill to get it to match the stbd engines boost. Sepentine Belts, not cog belts. I think you’ve ruled out about everything else.
endeavor1 is offline
Old 06-28-2021 | 10:23 AM
i put new serpentine belts on both sides over the weekend and tightened them up to the point I was afraid to go any tighter and no change. Hooked a computer up and it shows zero boost @ 4000 rpm.
Old 06-28-2021 | 11:38 AM
Where is it picking up the boost pressure at ?
green lightning is offline
