closed cooling? >
closed cooling?
closed cooling?
Old 07-07-2021 | 07:56 PM
Default closed cooling?
I'm having a problem finding an heat exchanger to fit under the engine hatch, How many are running raw water systems in salt water. Its a brand new engine and I would hate to but salt water thru it, Can the heat exchanger port be desolder and repositioned without damaging the cooler?
Zinger is offline
Old 07-07-2021 | 08:26 PM
seafordguy's Avatar
You could mount remotely? Park35 on here has his mounted remotely and they look great!
seafordguy is offline
Old 07-08-2021 | 07:51 AM
madbouyz's Avatar
^^ Going remote is a great option ^^
We get so used to seeing factory front mount installations that we often think it's the only way .
For some time now Volvo has been putting theirs upright (from the factory) on the front stbd side .
Def want that FWC though !
madbouyz is offline
Old 07-08-2021 | 08:01 AM
Default Upright exchanger
Does any have suggestions on who make and stand alone upright exchanger with a bracket
Zinger is offline
Old 07-08-2021 | 08:24 AM
madbouyz's Avatar
Some very useful links/references in this thread ..
Let's talk Mercury direct replacement Heat Exchangers:
madbouyz is offline
Old 07-08-2021 | 05:31 PM
It can be done...as seen here
park35 is offline
Old 07-08-2021 | 05:45 PM
https://www.mrcool.us/
https://www.cpperformance.com/c-1527...ling-kits.aspx
https://www.perfprotech.com/mercruis.../category/1287
1/2 system is block only. (exhaust manifold and riser gets the salt)
full system is block and manifold (risers get the salt), but you probably know that.
outonsafari is offline
Old 07-09-2021 | 02:07 PM
jrz
jrz is offline
Old 07-10-2021 | 01:02 AM
I like the version of Park35 very much ....
What is the origin of this superb installation?
Achievable on my 500 efi in the lower part I think
bajalux is offline
Old 07-12-2023 | 03:29 PM
Park 35 That's a nice clean heat exchange system. Is it a kit? I am in the process of rebuilding my 27 Activator engine and want to convert to a heat exchange system. Did your system come with the brackets and hoses or did you fabricate. Can you tell me the brand kit or make and length of the intercooler. Thank you for any info you you can give me. Very nice Job and also engine!.
TwoKs is offline
