Lean condition on odd Cylinders - Mercruiser HP420
Wish I was a little closer, would come over and take a look. I love mysteries
Not sure what that would prove ? I would think you could almost watch the exhaust and see if there was a lot less water coming out of that pipe ? Maybe compare it to the other engine too. Could something up in the thermostat housing be restricting flow only on that side ?
Ill buy lunch at Kent Narrows!
Haha, Thanks Bill. Everyone loves a good engine Mystery! I meant to use the plugs to flush the block out as best as possible. This boat actually came from Huntingtown, MD off RT 4 by the bowling alley. I also have family located in Prince Frederick. I wish you were closer as well, need a fresh set of eyes on this thing. You're only an hour and half
Ill buy lunch at Kent Narrows!I was coming over to Denton pretty regularly to see my Brother in Law but he unfortunately passed away in May
I know the route pretty well
The amt of psi to blow out the spark plug porcelain like that is super high. Detonation and/or preignition is probably the culprit.
Last time i saw plugs like yours was when nitrous was in it’s infancy. Damagecwasn’t usually limited to the plugs unfortunately. Those where confusing and costly days. Lol.
Also, buy your AcDelco plugs locally, not from internet, just in case that is an issue.
No expert, but I do know how to tear things up.
haha, thanks Jamontes - I share the same experience with tearing things up just to fix them. So these 420s run the HPV8 modules with 20* advance. Factory recommends 14* initial but once I had issues I backed the initial down to 8* to be safe. No change, still melting plugs on the port side.
When running in the bay on Saturday, engine temps we lower than I typically see here locally and were around 150 on the old VDO gauges. On Sunday, temperatures on the gauges were in the 170 range as I typically see when running on the river. Our river temperatures are upwards of 85F this time of year.
This may not be the cause but does point to a cooling issue.
