Merctrans 2 no forward or reverse >
Old 08-10-2021 | 04:45 AM
Default Merctrans 2 no forward or reverse
Merctrans 2 ran good for about 45 minutes and shut off when I started it and put it in gear there was nothing..shift motor working..but I now have more trans fluid in trans.. when I started out it was on the full mark now I'm way past it anyone else have this problem??
Sean Shields is offline
Old 08-10-2021 | 06:05 AM
Rookie's Avatar
I had a leak in my trans cooler that added water to my transmission and then it would slip.
Rookie is offline
Old 08-10-2021 | 06:20 AM
I have checked it and it doesn't have any water in it but my power steering is low like it's sucking it out and looks as if some has come out of the vent..it's driving me crazy
Old 08-12-2021 | 07:26 AM
Is the electric shift operating as it should. Maybe disconnect and shift manually.
getrdunn is offline
Old 08-16-2021 | 04:04 AM
I tried to manual shift it seems like it has lost all pressure from the pump in the trans..I've drained it a couple times and nothing...it's just disappointmenting
Old 08-16-2021 | 04:07 AM
I would like to have a manual or anything I could print out and easier to read.if anyone could point me in the right direction..thank you
