Engine stalls stalls when put Into gear! >
Old 08-15-2021 | 01:37 PM
did you pump out all the old fuel ? Id think those carbs would need a bebuild with old gas setting in them for 2 yrs
didn’t pump out all fuel, was told it was winterized properly! Not much fuel was in there I just put in 94, being the highest fuel pump fuel we got up here in Canada, I’m thinking if it’s bad fuel wouldn’t both motors be experiencing same issue?
NickSkyline is offline
Old 08-15-2021 | 02:18 PM
Why not try switching carbs?
rer233 is offline
Old 08-15-2021 | 04:01 PM
What rpm are they at in neutral and what rpm when put in gear?? What kind of carbs??
Probably just needs the idle air bleeds adjusted or maybe just the idle rpm.
Griff is offline
Old 08-16-2021 | 06:19 AM
idles just under 1000, not sure the exact carbs will look today
Old 08-16-2021 | 07:07 AM
SB
Originally Posted by NickSkyline
yes carbed motors, I just bought the boat and got her on the water yesterday. Timing was set few days ago by a local reputable shop. Boat sat for over two years prior.
Two years of sitting for Holley carbs, the carbs will need to be pulled apart and cleaned. Easy peasy.. I do 5-10 a year. Just one last week. Ski boat, sat last year. Week before 502 w/BG 850. Litte over 12 months ?
Make sure that shop set timing by total timing method, not initial. Performance motors with spring type centrifugal advance some times are already advancing at idle.
SB is offline
Old 08-16-2021 | 07:24 AM
I’ll pull it off giver a clean today! Thank you
Old 08-16-2021 | 07:33 AM
SB
Make sure you use red straw and blast both ways thru the top air bleeds 4 per side. 2 are idle and 2 are high speed. Some miss this for some reason. Watch your eyes, carb cleaner will squirt back at you. Compressed air after doing this is better. As after spraying thru (both ways) all holes in metering blocks and bodies.
Best way go set idle mixture screws are in the water, engine fully warned, and in gear. Typically best idle in neutral will need screws opened (counter clockwise) another 1/8-1/4 turn.
SB is offline
