Promaxx heads and Valako >
Old 11-07-2021, 05:22 PM
Received 1,322 Likes on 693 Posts
Default Promaxx heads and Valako
Jim has done an awesome job on my heads. A very reduced sized intake ports and flowing near 415 cfm at .600 and 450 cfm at .700 lift. Gotta love old school head porters that outflow CNC heads. The air speed is insane on these. All out of a 317 head. Just wanted to give jim a thumbs up.
getrdunn is offline
The following 11 users liked this post by getrdunn:
articfriends (11-08-2021), Griff (11-08-2021), hogie roll (11-08-2021), KAAMA (11-19-2021), PROP STAR (05-24-2022), Rookie (11-08-2021), SB (11-08-2021), stealthfever (11-09-2021), sutphen 30 (11-07-2021), ThisIsLivin (11-08-2021), TomZ (11-07-2021)
Top Answer
05-18-2022, 03:39 PM
getrdunn
Just a little update. We ran into P/V clearance issues with the bigger valves so had to disassemble short blocks and fly cut the pistons. Back on track but about two months behind schedule. Now ready for the dyno tune.
Old 11-08-2021, 10:19 AM
I am very interested in the lower lift numbers, can you post those as well?
ThisIsLivin is offline
Old 11-08-2021, 11:14 AM
.200/178
.300/243
.400/317
.500/370
.600/413
.650/439
.700/450
.800/463
port is 1.750 x 2.250
cams are SR 255-259/704-704 net
This has been in the works for some time now with delays on my end “with builds” til now. Jim’s just been working on these on and off during spare time however making improvements along the way.
I am confirming cfm @ .300 this afternoon.
getrdunn is offline
SB (11-09-2021)
Old 11-08-2021, 04:50 PM
Those are mighty impressive numbers. How good is the exhaust side.
Smitty275 is offline
Old 11-09-2021, 07:47 AM
Those are really good numbers especially for the port size. What size is the intake valve? I would be a little concerned about the velocity, you have to be on the edge of going sonic.
Old 11-09-2021, 08:18 AM
Pretty certain 2.300. He wanted 2.350 however I was a little concerned with piston clearance. Short blocks assembled and anxiously waiting. NA builds.
getrdunn is offline
The following 7 users liked this post by getrdunn:
articfriends (11-09-2021), CDShack (11-10-2021), Gimme Fuel (11-09-2021), PROP STAR (05-24-2022), SB (11-09-2021), ThisIsLivin (11-10-2021), TomZ (11-09-2021)
Old 11-09-2021, 12:32 PM
articfriends's Avatar
amazing numbers on top, whats really surprising (on top of the outstanding high lift numbers) is whatever work jimmy V did to get them there did not hurt low lift flow which I would expect on something that gains so much on top. Cant hardly wait to see the outcome on the dyno. How big are your new motors, whats compression going to be, Smitty
articfriends is offline
Gimme Fuel (11-10-2021)
Old 11-09-2021, 12:48 PM
F-2 Speedy's Avatar
Received 2,436 Likes on 1,118 Posts
Those billet timing covers are sweet
F-2 Speedy is offline
1983ScarabIII (05-23-2022)
Old 11-09-2021, 12:55 PM
Tks guys - their 565, 4.25 stroke, dart blks, 10.5:1. He’s got my Brodix hv 2001 intakes and 1150 two circuit carbs but Jim’s pretty adamant about claying up a profiler sniper intake and seeing what he can do with it. I kinda always thought with the same amount of porting etc the gains would be minimal btwn several of them.
If I see 700 plus “anything” at More Power Racing’s dyno I’d be happy. Just want a good tune and reliable engines. Since they did all my machining, balancing etc I had them do the assemblies since everything was there.
I always got a kick out of that engine I believe you dyno’d smitty with the chinamen intake and out performed others. 😂
getrdunn is offline
articfriends (03-24-2022)
Old 11-09-2021, 03:35 PM
yeah, i pulled that 548 about 100 times trying various intakes, efi and carbs na , made outstanding hp on top (707) at 6300, 6400 if i rember right but what it didnt make was tq which was in the 620 area. But, keep in mind it was a 8.4-1 blower motor with good flowing heads, giant cam but no blower. I've dynoed alot of engines since then, glad to see you putting some compression in these, I've dynoed quite a few engines others built with 8.8, 9-1 w open plenum intakes, high flowing heads that made less tq than smaller engines with modded mpi intakes and performer rpm intakes!
The following 4 users liked this post by articfriends:
Gimme Fuel (11-10-2021), PROP STAR (05-24-2022), SB (11-09-2021), ThisIsLivin (11-10-2021)
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
