What would be the best cam? >
Old 01-16-2022 | 01:36 PM
Boostedbigblockboat is offline
Old 01-16-2022 | 05:40 PM
Originally Posted by Boostedbigblockboat
There's gotta be something that sounds choppy with little overlap atleast a slight bit better with thru hulls right off the turbos even the slightest change should be noticed?
yeah,there is,,get rid of the turbos,,they act like mufflers.
sutphen 30 is offline
Old 01-16-2022 | 06:48 PM
Two pages and nobody’s pitched a cam from Bob ?
JaayTeee is offline
Old 01-16-2022 | 07:13 PM
easy there or else black SUV's will be pulling up to take away your computer
compedgemarine is offline
Old 01-16-2022 | 07:22 PM
phragle is offline
Old 01-17-2022 | 11:16 PM
mcollinstn's Avatar
You don't want a "choppy" cam in a low compression turbo 454 with cast components. The cam dictates the Rev range where the motor is most efficient at making torque. Your cast motor should be kept below 4900-5000 rpm.
We also have no idea how well the turbos will spool up with a cam that has a torque peak way faster than your "planing rpm".
If somebody ran it like it is, then start there.
You really shouldn't jump so far ahead of yourself.
Besides, you need to creep up on speed with your new hull..
Find the casting numbers on your pistons and send photos.. Find the casting numbers on your heads. Find the stamped number's on the face of your cam. Those are good starting info we need in order to help you..
mcollinstn is offline
Old 01-17-2022 | 11:23 PM
Much appreciated once I get time to tear into it for maintenance before slapping it in for summer il get all photos and info
Old 01-18-2022 | 06:24 AM
Now that’s funny! 😂
getrdunn is offline
Old 01-18-2022 | 05:15 PM
SB
Ass u ming the engine is truly a 330hp 454 base, and me having 0 turbo exoerience, i would put this one on a list of considerations:
https://www.summitracing.com/parts/s...make/chevrolet
SB is offline
Old 01-19-2022 | 10:48 AM
Nope I’d get this. Why?
https://www.compcams.com/pub/media/w...HR-14(LS1).wav
Cause it sounds good!!!
getrdunn is offline
