Dry joint to wet joint conversion? >
Old 02-17-2022 | 11:40 AM
Default Dry joint to wet joint conversion?
Is this a simple bolt on swap? I have a Gen VI 502 mag MPI that is being replaced by a new long block. Currently it has stock dry Mercury manifolds, elbows and 4 inch risers. Can I replace them with stock mercury wet style manifolds/risers/elbows? Yes/no...pros/cons? Thanks.
lear60man is offline
Old 02-17-2022 | 12:05 PM
Picture of current set up
Old 02-17-2022 | 12:12 PM
scarabman's Avatar
Why go to wet style? If changing exhaust, you wouldnt want to do SM or Imco, or such?
scarabman is offline
Old 02-17-2022 | 12:19 PM
SB
Looks wet to me. But i’m looking at it on a small ohone.
SB is offline
Old 02-17-2022 | 12:54 PM
I'm with SB on this one. Current picture shows a wet joint setup with a 4 inch spacer between manifold and riser/elbow. The brass plugs shown would have an interconnecting hose for coolant flow between the manifold/riser if this were a dry joint setup.
Trash is offline
Old 02-17-2022 | 01:08 PM
You have a wet joint between manifolds and risers. If you didn't, no water would be in the exhaust and your exhaust would be on fire.
Griff is offline
Old 02-17-2022 | 02:02 PM
Ok...now im confused. I thought a dry joint was a set up that uses square gaskets and a wet set up (2005 on-wards?) has square gaskets with round openings on the sides like this: https://www.perfprotech.com/kit-rise...product/188519
If the current set up isnt leaking, Ill just replace gaskets when the dead engine comes out. But if it leaking at the joints, I was exploring options to see if it was possible to go with a set up like in the above link (manifolds, risers, elbows etc).
Thanks for the insights.
Old 02-17-2022 | 02:36 PM
That is the wet style joint, meaning the water flows through the outer flange with the exhaust in the center, only a gasket separates them, a dry joint will have a jumper hose from the manifold to the riser, eliminating any water intrusion at the actual manifold/riser joint
Compare your current setup to a 496, you will clearly see the difference
blownhammer2000 is offline
Old 02-17-2022 | 02:44 PM
Thanks......make sense. Still need to tear this one down and find out if they are bueno or no bueno.
