Power trim toggle switch replacement, what amperage is needed? >
Old 02-28-2022 | 07:56 AM
Question Power trim toggle switch replacement, what amperage is needed?
Hi, My bravo drive has a toggle switch on the wheel, and it's getting sticky and needs to be replaced. And it has to fit in the anodized bracket (looks like a standard size, about 1" long)
The specs are 16 (4) A 250V~t85u 16A 250VAC Non Ind (not sure what the 4 in brackets means?)
And the switch is a C1522WR
This is what came with the boat, installed by DCB, so I assume it is sufficient.
The one I did find that looks the same size, so should fit has these specifications:
ITT CM Seriers
16A 125 VAC 1/8 HP
10A 250VAC 1/3HP
Please let me know.
Thanks!
2Slow4me is offline
Old 02-28-2022 | 08:04 AM
SB
Very little amps. I’m sure less than 1.The switch just sends low power to the relays on the pump which handle the high amp loads.
SB is offline
Old 03-02-2022 | 07:51 AM
Ayuh,..... 'bout any momentary 3 position toggle switch will work,.....
I've added several in different places on the boat, run in parallel with the original,....
The one on the transom is the handyist, can trim/ tilt the drive, without crawlin' into the boat,....
Bondo is offline
