E 15 going on sell this summer
Won't keep it cheaper for long, 2 million less acres of corn were planted this year. It also goes against the regime's claimed climate friendliness as it produces more smog in summer. Yet another moronic decision.
No mean tweets though!!
I run e85 in my twin turbo street car. When I say there is a lot of heat under the hood, I mean there is a LOT of heat under the hood lol.
Never had vapor lock.
But, your pump is probably in back of car and gravity fead ? And your fuel returns to tank ?
That is merc’s issue. Fuel not gravity fed to pump and Vapor making it to inlet of pump because return goes back to inlet of pump, and then it cavitates and doesn’t move the fuel.
I saw that too, real math tells us going from "e-10" to e-15 would result in a loss of 1.5% of total energy content per gallon (ethanol having 30% less energy per gallon than gasoline). then in equivalent power, theoretically a motor on e15 will make same power as a motor on e-10, it will just use 1.5% more fuel to do it.
Cool !
I understand the difference in the merc setup. Don't The boats that have this problem, (i never did on my 496ho), have the problem with no ethanol as well?
The 496 came with a fuel cooler on it to combat vapor lock. It's built into the fuel filter assembly.
Ethanol is also leaner then gasoline so in absence of a closed loop 02 or a flex fuel sensor if your setup is right on the edge it could be troublesome.
