Hp525.   What would u do >
Old 04-18-2022 | 12:36 PM
F-2 Speedy's Avatar
Originally Posted by nocigarette
what gasket do I buy to drill the pattern any idea?
check this for your split top's 27-841234.........the 500 EFI is a standard bolt pattern
27-841234: Search Result | eBay
F-2 Speedy is offline
Old 04-18-2022 | 12:44 PM
nocigarette's Avatar
damn. Quick response. U always were a mound of knowledge I remember u answering a ton of questions back when I had my old magnum. Thanks again.
nocigarette is offline
Old 04-18-2022 | 12:52 PM
Non relevant question but what magnum did you have - 27’? Damm I loved that haul. Cuts the waves like BOSS!
getrdunn is offline
Old 04-18-2022 | 12:53 PM
SB
Exh gasket recommended for Edelbrock/GM 315cc aluminum head
Stainless marine sells a gawd awfully expensive jig /template to help. $750 i think. Doh !
SB is offline
Old 04-18-2022 | 12:57 PM
F-2 Speedy's Avatar
Those header flanges are a pita to drill ask me how I know........
Old 04-18-2022 | 01:22 PM
Probably easier to drill and tap the heads to the conventional bolt pattern
snapmorgan is offline
Old 04-18-2022 | 02:02 PM
SB
Enquiring minds want to know
SB is offline
Old 04-18-2022 | 02:12 PM
F-2 Speedy's Avatar
I drill out 2 pair of CMI sweepers to fit the AFR heads.......................... the flange is hardened stainless
Old 04-19-2022 | 08:51 AM
that was my thoughts. Prolly be the fastest solution also.
wouldn’t I have to change or redrill my Cmi spit tops to fit the head configuration?
Dont fuk up those headers to fit those outdated heads. Buy brodix 298 RR or AFR 300 heads, run an edelbrock dual plane. Should make lots of torque and more power than a normal 525.
hogie roll is offline
Old 04-19-2022 | 05:42 PM
Not sure on the Brodix, but you cannot find a set of BB AFR heads for like 12 weeks. (maybe you can get the Enforcer heads, but the magnums are unobtainable).
xlint89 is offline
