Exhaust Cooling
Switched from Gil manifolds to Lightning headers on 2000 HP 500's with 4 hose exhaust manifold cooling, can only use 2 hoses now for the headers, Can i remove and block off the t-fitting with check balls and just use the 2 hoses from the cap or will this cause a flow or pressure problem ?
Originally Posted by THE NEED FOR SPEED
(Post 4830601)
https://cimg0.ibsrv.net/gimg/www.off...8cb2b3fdfe.jpg |
(Post 4830601)
Originally Posted by SB
(Post 4830619)
Most peep’s typically use a Y connector. Most performance exh manufacturing companies sold these for install.
Nice clean looking set up there
You can get the 4 hose tstat housing then. It has just 2 outs.It is found on 454/502mpi engines and some others.
Looks like this. https://cimg6.ibsrv.net/gimg/www.off...2ee56986f3.png |
Originally Posted by xlint89
(Post 4830655)
| All times are GMT -5. The time now is 11:40 AM. |
