Oil Filters
Damn, you have the 1-1/2" thread? I guess all of the cross reference places are wrong. I believe we ran those in the race boat. It was a pain finding filters for the non-standard BBC filter head. I believe we ran a Fram filter. I'll see if there are some still laying around.
Ive seen some Baldwin filters go down to 9.8 micron...
Just wondering why you want to go so small?
-Wally
-Wally
performance engineering did my motors and said not to use the racing filters as they were meant to be changed say after every race in a car car. ive tried both and never noticed any pressure changes so why not go with the better filtration?
now i'm really confused.......
Everyone has opinions, mine is, I like better filtration but with a high volume oil pump its moving a lot of oil. Reducing the particle size may reduce flow (don't know). Going smaller may need to use 2 filters in parallel to keep the flow up
After doing a bunch of research the Fram HP6A seems to be the best filter for the bigger 1.5"-12 filter threads. 20 micron rating, 20 psi relief valve with a screen, thicker metal. The standard filter by Fram is low quality cardboard, however this one seems to be built he best.
https://shop.donaldson.com/store/en-.../P550832/20534
OP has something totally different.
That has the standard chevy thread size, no ?
Saw another post on FB that compared micron rating, flow rate and pressure from an episode of Engine Masters where they tested a bunch of them. I used to run the Wix Racing 51222R and switched to the K&N HP-5001.
