502 MPI Intake and Injector Question >
Old 05-17-2022 | 08:21 PM
Originally Posted by Wally
I think your mechanic may be mistaken....doing a search on the 805225A1 it looks like those are for 94-96 motors.
I think the ones you have in there now are correct for a 1999 (they fit 1998-2001...
The boat is a 1999. Motor suppose to be 1999. The injectors on it are injectors from 1999+ per schematic and model.
The intake is not. It is pre- 99, but someone prior to me modified it to fit the 99 injectors (smaller than the older ones that usually go into it).
seems that I need a new intake that will fit the injectors that are there (small in size). Per schematic it is 861300A2.
issue is I can’t find any and I have a new intake, but it is pre 99 and fit the bigger injectors only.
srdrago is offline
Old 05-17-2022 | 08:22 PM
Originally Posted by AllDodge
What's your motor serial number?
Ill grab it but I block is dated after 1999.
srdrago is offline
Old 05-18-2022 | 07:01 AM
With intake being modified it won't matter now
AllDodge is offline
Old 05-18-2022 | 09:40 AM
How can I fit a 861260T Injector into my 805233C manifold. The 805233 Manifold takes a bigger injector (805225)
Attached is photo of the 2 injectors. The small is what I have on my motor now (861260T), the big one (805225) is what fits into the manifold I have.
srdrago is offline
Old 05-18-2022 | 10:07 AM
TomZ's Avatar
I have a ‘98 intake as well as a better than factory set of injectors. The intake isn’t in the best of shape but it did seal well using the factory Merc gaskets. Send me a PM if interested.
TomZ is offline
Old 05-18-2022 | 10:22 AM
would your set up work with my computer? What if the injectors are not the same as what the computer is set for?
srdrago is offline
Old 05-18-2022 | 10:34 AM
F-2 Speedy's Avatar
What ecm do you have ? how was the intake modified for the smaller injector
F-2 Speedy is offline
Old 05-18-2022 | 10:41 AM
should be MEFI-3
the studs of the intake was shaved down and injectors jellied into the hole. It worked for a season.
but now I am putting a new block into the boat and was going to change the intake to a new clean one and my mechanic saw this. Now I can’t find a intake that fits the smaller injectors.
srdrago is offline
Old 05-18-2022 | 10:42 AM
My original 502 motor 415 HP used MEFI-1, manifold 805223 and injectors 805225 (37 psi)
The motor was repowered 530 HP using a MEFI-3 with same intake and injectors (40 psi)
Either MEFI will work just make sure the fuel tables are done correctly when re-flashing
AllDodge is offline
Old 05-18-2022 | 10:48 AM
what year was your 502?
I really don’t want to deal with flashing and keep the current injectors that are with the motor. But I can’t find a intake to fit them
not sure if there is a adaptor or something to make it work?
looks like these injectors fit to a intake number 861300A2
srdrago is offline
