575sci issues >
575sci issues
575sci issues
Old 05-25-2022 | 03:44 PM
  #31
F-2 Speedy's Avatar
Originally Posted by bolin22
Yes, it def has an IAT in the flame arrestor.
The weird part is the scanner is reading Manifold Air Temp....
My wooples have a MAT sensor in the rear of the lower intake plenum...........Eddie would know for sure
F-2 Speedy is offline
Old 05-26-2022 | 10:49 PM
  #32
articfriends's Avatar
IAT/MAT are one and the same on these mefi engines fwiw
articfriends is offline
Old 05-27-2022 | 11:21 AM
  #33
Thanks for that info on the IAT.
I pulled the linkage off at the TB and watched the scan tool while manually opening the throttle blades. TPS voltage at idle was .54V and started increasing immediately, but would raise to .84V before the TPS % started to climb off "0"...Not sure if this is significant or not.....?
Looked over wiring and connections for TPS, MAP, IAT; checked the distributor cap and rotor for corrosion; checked the vacuum lines for cracking or kinking etc,
Next steps?
I am going to plumb in a mechanical fuel pressure gauge and closely watch that....looking for other ideas here. Summer is coming and I am getting frustrated lol.
bolin22 is offline
